Overdrive light blinking
I have a 1997 F150 rear wheel drive with 4.2 liter engine. My overdrive light on shifter blinks after driving a short distance. If I then shut off the engine and restart the light will stay off longer. I took it to the transmission shop and they test drove. They told me that the transmission had no fault codes (even when light was flashing) and it test drove fine shifted in all gears. They determined that the unit on the side if the transmission was bad (they called it a “prein”???) sending incorrect info causing the overdrive light to flash.
They want $300 to fix, can anyone tell me what the unit on the side of the transmission is, would that be the problem and how hard to replace???
