M5OD fluid
on
Bookmark this, it goes back about 10 years worth of models:
https://www.fcsdchemicalsandlubrican...n/quickref.asp
Tip - make sure you can get the fill plugs loose before you drain them.
The factory only uses RTV on the diff cover, which has to be removed to drain it. Autozone has gaskets for the 8.8 if you would rather use one instead of RTV. I use both - a gasket and a thin skim of RTV on both sides.
This makes the fill a lot easier:
http://www.harborfreight.com/oil-suction-gun-95468.html
