Pulling engine and tranny on 2002 F150
During assembly at the factory, the drivetrain is in place before the cab goes on. I would suspect that you MIGHT be able to get the tranny and engine out in one piece, but it would be much easier on you, and damage free to the truck to separate the two. Probably easiest to pull the tranny first, then engine, and then reverse the process to put it back together...
