Transmission issue??
Changed the filter and fluid on Sunday, and before that everyhting as fine shifted fine, took off from a stop great. Today(Tuesday) driving to work everyhthing was fine(and everything has been fine until today), I was making the last turn into work and after slowing for turn went to acclerate and the truck didi not really want to go, reved her up a bit and she took off, slowed back down same issue? Reverse is fine, is it possible to have to much fluid i there? I draind the pan and torque convertor and replaced all that with 12 quarts?
2001 F150 Supercrew 4x4 5.4 4r70w transmission
Any hell will be appreciated, have alot of mountain driving to do soon.
Thanks, Marty
Thanks, Marty
Go back and read my post above to see how you need to check the fluid if you really want to know if it is right or not.
on
If the engine isn't running the pump, the fluid basically drains back into the pan instead of being in all the places in the transmission where it's supposed to be causing it to read "High" on the dipstick. The fluid both has to be up to temperature (thermal expansion) and it must be pumping to get an accurate level reading.
