4R75W 2004 F150 LARIAT Leaking
So, I was installing some headers, and there was a mishap with Pacesetter, and OBX. So for three weeks total, while I fought and waited on shipping from both of these companies (and ultimately ended up with stock manifolds ) my truck was on jack stands, with the front in the air, no wheels, the rear on the ground. Grant it, it wasn't a steep angle, but an angle nonetheless.
When I started putting it back together, I noticed the transmission pan had fluid all over it, and it was pooling under my vehicle. SO, it was time for a service, I removed the pan, replaced the filter, and torqued everything back up. But the leaking didn't stop.
I've read that on the 2009's there is a bulk head that leaks, but I looked at mine, and it wasn't leaking. I'm sure it's not my pan leaking, it's coming from somewhere else, I just can't seem to find it. Has anyone come across this?
It has the same symptoms; leaks mostly if it's sat for two days or so without running, the stops!
I'm at a loss!
Have you seen this?
izzy
I'm at a loss!
Have you seen this?
izzy
UPDATE***
I jacked it up a little today, and crawled underneath. There is a bulkhead/electrical connector on top of the transmission, on the passenger side. I pulled the plug, and it was filled with transmission fluid in the harness. Plus it's wet around and underneath. I'm sure this is where the leak is coming from.
