Need Help Replacing Transmission
I know this is off the thread but there is no site that I found to give me the answers I need I have a 2002 E150 5.4 and with a 4r70w that is trashed. I have 4r100 transmission an trying to figure out how to make work in. I'm low on funds otherwise I would just replace the transmission needed but I know the 4r100 is a good transmission. Understand that wiring an replacements will be needed would anyone be able to help me out with details or where I could go to find the right answers thank you for your time
If your low on funds you can try a shift kit for the trans you have and use GOOD trans fluid to fill it back up with.
Lilgnomey85, I moved your post to its own thread. I think you might get better responses that way. I also deleted the duplicate post you entered in the General Discussion section. Duplicate posts tend to create confusion.
Welcome to the forum. I hope your problems are taken care of soon.
- Jack
- Jack
You need a new wiring harness, or the ability to build one. The 4R70W harness won't connect to the 4R100. You'll need a wiring diagram for a 5.4L/4R100 to be able to construct a harness.
You need a computer for a 2002 5.4L/4R100. The computer in your truck WILL NOT run a 4R100.
You need to move the transmission crossmember. The 4R100 is longer than the 4R70W.
You need to shorten the driveshaft. The 4R100 is longer than the 4R70W.
As long as the 4R100 you have is for a 5.4L or 6.8L it will bolt to your engine. A diesel version will not.
my engine and transmission has 121,000 I was driving at one night and I heard two pops then it went into neutral from there I would lose 3rd gear it would just go into neutral after hitting 3rd gear and I also lost reverse I have to remove the transmission from the van but have not cracked it open or done anything else suggestions for that please and thank you, & I appreciate the replies I've gotten so far
