Trans will not go into any gear.
If it is an automatic look under the dash on the driver's side. Check that the shift lever is moving the bracket that holds the shift cable moves with the lever. There are two #30 Torx bolts that loosen and fall out. If they do then the lever moves very easily and won't control the transmission.
