what is a good 5spd for my 300 L6
If you want tough about the only choice you would have is the ZF5 that came in the F-250 and F-350 between 1988 and 1997. The zf5 that was behind the 300 l6 and the 351 has the same mounting as far as bolting to your 300. From what I understand, they never put a ZF5 behind a 302, although it should bolt up.
You will probably have a few issues with hump in the middle of the floor and the location of the shifter. I'm sure a few other issues as well as maybe a custom driveshaft, I'm sure you expected all that.
Is your 85 F-150 2 wheel drive or 4 wheel drive?
