o/d light flashing
o/d light flashing
Maybe I shouldn't complain about 175k out of a trans, but it's been well cared for and never towed anything.
However, tonight I noticed the o/d off light started flashing. For the past few weeks, the shift indicator has not been lining up right, and one night I pulled the lever into drive, and it felt like it didn't drop in all the way, like the detent or whatever didn't end up in drive fully. The truck barely moved like the trans was slipping. Then, I pulled the lever into 1, back up to D, and it lined up and engaged properly.
Now, several hundred miles later, the o/d off light flashes and trans is no longer in o/d. I shut the truck off and it reset.
I really need to drive it tomorrow, anyone know if the trans is the issue? Just can't afford to get stranded, working on a job where I'm relied on and also can't replace the truck at this time either.
Thanks for any help.
Hey glc, you got it right! I found an article about the loose bolts, so went out and wiggled the shift lever while watching the bracket. Sure enough, sloppy. The bolts were very loose. Tightened them up snug for now (it's cold) so will do threadlock later, but made it tight like new.
Thanks.
Thanks.
They were lying to you. The flashing OD light means a code is stored. Without reading the codes they don't know why the light is flashing. It could be something very simple, or it could mean a rebuild.
A damaged wire outside the trans can make it flash. So can a bad speed sensor in the rear axle. Neither requires a trans rebuild to fix it.
