please help tranny problems
i have a 06 lincoln mark lt 4x4 and i was driving and all of sudden truck shut down and tranny failure lite came on . it starts up fine but wont go into gear but when you put it into reverse works fine its getting code p0720 any ideas im going try changing the oss sensor in little while but have feeling its not it any help thanks
tranny problems please help
ok so i changed oss sensor cleared codes and still did same thing no gears just reverse but i rescanned it got 2 different codes p0743 and p0755 and od light stays on and tranny malfunction light . then i checked fluid it seemed low i added a qt and lights went out and tranny moves little not much kind of rolls l but it didnt move at all before i cant tell if it needs more fluid its all over dipstick everytime i take it out and recheck it i will let it sit over nite let fluid in dip stick settle
Look underneath, if you don't have an apparent leak, then you aren't losing fluid. So now you may have 'overfilled' and will want to drain it now. Drop your pan and change the trans screen, maybe a plugged screen will cause this issue. If so, new screen PN: F6AZ-7A098-A. Either way, it sounds to have gone into a fail-safe status so something electronic is wrong.
http://www.obd-codes.com/p0743
http://engine-codes.com/p0755.html
