1992 F150 E40D Tranny Problem
Transmission goes into gear (3rd) sluggish and the rear drive's wheel locks up as if the emergency brakes are applied. Very hard to pull off and engines dies if accelerated hard while engine is cold, gets a little better when warm. The O/D switch (light on gear selector) is not illuminating. Pulls off better in 2nd gear but does not shift. When manually shifted from 2nd to 3rd gears it is a hard shift. The tranny is used from pick n pull junk yard but the removed tranny did the same thing. Are there external sensors or switches that could be causing these issues. Check engine light is not on but this is a OBD-I system. I was told that there is some type of module at the end of the steering column that is wire to the gear selector that may cause similar problems.
