1990 F-150 Lariat
1990 F-150 Lariat
I recently purchased a 1990 F-150 2wd. It has the 302 (3:55 gears) with ~71k actual miles. It doesn't appear the transmission fluid has ever been changed. I have read multiple mixed reviews on whether to flush the transmission and change the filter or just drop the pan, change the filter and replace whatever fluid is needed. It makes me nervous to do the complete flush and end up with problems. Currently, there are no odors or issues. Any opinions? Thanks! Hopefully, not mixed like everything I have read.
I contacted a local Ford dealership and the service individual recommended to drop the pan and replace filter vs. the flush. I don't know anything about transmissions. That is why I am researching here. It is not about not doing any maintenance. It is about what maintenance to do. The truck is new to me and I want to take care of it.
Dealers and other shops generally don't drop pans any more, they just use an exchange machine. That's a good way to do it as long as they use it in the passive mode, using the internal trans pump to move the fluid instead of putting it in flush mode.
You can definitely save money doing it yourself, but it's pretty messy.
No write ups that I know, but all that is done is to use a socket on the front crankshaft turning it until the plug on the TC is visible at the hole at the bottom of the bell housing. The hole will be covered by a small rubber plug. Drop the pan first and replace the filter. I don't believe the pan gasket is permanent like newer model vehicles, so it will have to be replaced.
e4od has a rubber plug on tc, aod has a inspection plate on front of tc you remove the three bolts. Don't even have to drop the pan, no one does that anymore. Use a fluid suction pump. $4 from harbor freight. http://www.harborfreight.com/multi-u...ump-66418.html find some coupon to go with it..slickdeals.
