4r100 creep
It's not unusual. It is caused by drag of the ATF in the clutches. Sometimes new fluid will help reduce this, running synthetic will definitely reduce it.
There is nothing that can be easily adjusted. You could rebuild the trans and set the clearances in each clutch to the looser end, but that's a lot of work for little gain.
