Transmission Fluid Leak
Old 03-20-2017, 04:09 PM
ggreg's Avatar
2010 F150 trans leaking (simliar to other peoples issue)
Hello, I have a 2010 F150. Last month I changed the fluid, filter, and pan on my truck. There has been no leaks for a month. Recently went away for a weekend on a snowboarding trip so my truck sat for 3 day without moving. The temp get down in the low 20s. When I came home there was a decent size puddle underneath the truck. It looks like it was leaking from the rear area of the pan. I went around and checked to make sure all bolts were still tight but did not find any loose. Any thoughts?
Old 03-21-2017, 05:17 PM
Mark Kovalsky's Avatar
Did you reuse the pan gasket or use the cheap cork one that came with the filter?
Old 03-21-2017, 05:22 PM
ggreg's Avatar
I had purchased a new gasket from Ford. Gasket was make out of metal with a rubber line on it for sealing
Quick Reply: Transmission Fluid Leak
