'98 F150 Manual won't go into any gear
I have a 4.2 liter f150. When the truck is turned off I can put it into any gear without engaging the clutch. When I start the truck I can't put it into any gear. Any ideas? I'm guessing I might have to bleed the clutch since it does feel a little spongy might be some air in the lines.
If bleeding the clutch doesn't help, the tranny has to come out. It's quite likely a stuck pilot bearing and/or possibly a blown slave. While you are in there, you might as well get the flywheel resurfaced and replace the clutch.
With the engine off, put it in 1st and hold the clutch to the floor and start it - does it move by itself? If so, does it feel like it's just slipping or fully engaged?
Manual transmissions don't have a neutral safety switch. They do have a clutch pedal safety switch, but that won't block it from going into gear, it only prevents the starter from engaging without depressing the clutch.
Update
Thanks for all the tips. I finally had a chance to look at it again. In response to glc I put the truck in gear and started it and it didnt move. Once I gave it some gas and started to release the clutch it began to move as you would expect from a working clutch although it may have been catching a little earlier than i remember. Still couldnt get it out of gear though. If I do need to bleed the clutch is that a two man job and can it be done without making a mess? Im not supposed to work on my vehicles at my apartment. Im wondering if I can drive it to a nearby shop. Just start it in 2nd and cruise there. Or isnt there a trick where you can change gears once you get it up to a certain rpm without the clutch?
Oh and the truck has 176,000 miles
I'd advise you to get it to a shop where they can figure out exactly what's going on. If it has 176k, I'd be prepared for a full clutch overhaul. Going price to do it right is in the $1200 range. Doing it right involves a complete clutch kit - disc, pressure plate, throwout bearing/slave cylinder, replace pilot bearing, bench grind or replace flywheel, and replace the rear main seal if it's leaking or seeping at all.
It really does sound like just a stuck pilot bearing, but at 176k there's probably not much life left in the clutch anyway. Everything has to come out to even get at the pilot bearing, it's pressed into the flywheel.
Now you're in neutral, for me the easiest way to do this is to wait for the RPMs to settle then slowly give it some gas and push it into gear easy. When the RPMs of the input shaft and the gear you're trying to shift to match it will slip right in. Downshifting is the same idea, but in practice is it more difficult to pull off.
The basic idea, is say you are going 30 mph in 2nd gear at 3000rpm, in 3rd you'd be at 2000rpm. When you're in neutral, you make the input shaft speed or the motor speed match the speed 3rd gear is spinning at 30mph or 2000rpm. When both are spinning the same speed they mesh, not grind.
One problem is you will need to shut the motor off to start from a complete stop. I did drive a car to the mechanic like this years ago and now a few times a year I'll practice it just in case.
