Auto Transmission Life Expectancy
One thing I did between my opening post here and recently, was to go through the valve body. I found a worn overdrive regulator valve and bushing. Ripe for a future 4th gear band failure. And I replaced the pressure regulator ( for line pressure) and installed a Transgo shift kit. Kit raises line pressure among other things.... real nice btw....
One the subject of firmer shifts paving the way to a longer tranny life, could possibly on side two of the coin, shorten it. Me thinks increasing line pressure via an electronic tuner or in my case a stronger spring in valve body could stress the seals in those drums--- in otherwords blowing the O-rings. Especially in reverse. For some reason trannies in reverse make a lot more pressure vs. forward. I can tell in reverse that there seems quite of bit more firmness now, with that tiny little reverse spring they give you to put in the line pressure solenoid bushing..... it was optional for reverse; maybe I should've left it out......?
I would be interested in what you did to improve the 4R75E. I have had a slight issue with mine being a little rough at take off, but fine after that. So I have been looking around at Where and What you can do to improve the 75E. The thing is, I haven't found very much specific information on the 75E, the 70W, yes. That makes me feel as if these 4R75E must be pretty good transmissions if there is very little aftermarket support for them. If you have any links or recommendation on beefing up the 75E, please pass them along.
Mine lasted 58k miles and my dads lasted about 75k. He has a reman unit and i have a new one from Ford, hopefully I can make it last 100k this time
sorry did forget to mention I put in 2 qt. bottles of Lucas too. Helped a little but only the warm up works. Sounds crazy don't know why the warm up works but it does so I do. Trying to think of a tranny warmer so I can plug it in with a timer so I don't have to go out and sit in a cold truck.
thanks
Walt
thanks
Walt
thanks
Walt
thanks
Walt
I'm at just shy of 220k. I only got the truck at 180k about 2 years ago and I'm not real sure on the maintenance habits before I got it (I know he was real good about fixing problems and changing oil...) but its been flawless. Of all the things that have given me little issues, the tranny isn't one. Put Amsoil in it about 10k miles ago and the difference is incredible.
I still haven't found the barrel heater ( 350W @ 12V) I planned on putting on the transmission pan but probably not the best solution.
thanks
Walt
I usually just drive mine. It only takes about a mile or so to warm it up to 80, this is after letting the engine warm up also. Just make sure not to really get on the throttle until you're down the road a ways.
You could also get one of these to plug in with your block heater
http://www.google.com/products/catal...d=0CKEBEPMCMAU
The work around would be a custom burned chip. The quickest way to warm the transmission is to drive it. It takes forever to warm the trans if the truck isn't moving. It also takes a lot of fuel to warm the trans without driving the truck.
i have 260k on my 4r70w. i didn't get the truck til it had 128k miles on it already, pretty sure it wasn't touched though. at 200k miles i dropped the pan and changed the fluid in it and filter. very very little shavings on the magnet and very little clutch material as well.
i have a larger trans cooler i will be installing, but not until the trans gives up and i do a rebuild on it and flush the lines.
