4r70e to 4r75e SWAP
4r70e to 4r75e SWAP
Does anybody know if the 4r75e trasnsmission is a plug and play swap to replace the 4r70e????????????????(both +04)
i ask because my 4r70e overdrive band is gone and they say i need a new tranny. i am putting in a 2 valve 5.4 to replace the 4.6 and eaton m112 might be in my near future. so a beeferier trans would be a good idea
any incite would be great
Physically it is a direct swap. Electronically, everything plugs up but the sensor data from the OSS will be incorrect because of a change from 6 to 24 'holes' on the output shaft ring gear.
This can be corrected through tuning and it's simple to do. If you put it straight in though the thing will shift through the gears and into 4th before you can get out of the driveway because the computer would think it was going 4 times faster than what it really is.
Darrin
Darrin
Darrin
Darrin
I assume you can tear trans apart and swap the the output shaft ring gear as well?
what tuner would be able to do this. sct? i have a superchips.
yes and your tuner will have to be competent enough to adjust the shifts for the differences in the valve bodies. 5 star tuning did mine. Had my new xcal shipped the next day as well.
This is easy.
The tuner opens their tuning software to the catch code of your truck. They select the parameter for the number of holes for the OSS and changes it from 6 to 24. They then save the tune file and either load it into the tuning device or send it to you to load into your device so it can be loaded into your vehicle. You load it into the truck and that's it.
D
D
what for?
then whats 'GOTTS2BME' talking about with "take pan off, remove valve body, and replace the epc solenoid with a new one from your year of 4r70 trans, unbolt, bolt in, correct trans tuning via sct. I was the first guy to do it but I have a 4r70w which requires a wiring pig tail 159 from Ford. Easy."
what for?
what for?
