What 4r70w transmissions fit a '95 F150 2wd?
Do you still need help on what will fit?
Darrin
Yes I do, please. I've already bought the engine (a reman 5.0) and I just want to get the right trans in so I won't have to go through this again. A guy has a 4r70W out of a 95 cougar and he thinks it might fit. I looked at some pix of a 4r70w online and I'm going to see his tranny on saturday. But any help you can give me will still be appreciated, thanks again for all you help.
Let's start out with finding out what is in the truck now. Is there any way you can count the pan bolts or even take a picture to post up to show us?
But, let's assume that it is a 4R70W. If so then the one from a 95 cougar will fit both physically and electronically. Not a great transmission though. Unfortunately nothing that will fit straight in without changing something is going to be a great transmission, so that one is about as good as any from that standpoint.
Darrin
Darrin
So it isn't at all likely that the "wrong" converter or transmission were what casued the thrust bearing to fail. More likely what happened is that the converter ballooned and took out the thrust bearing. Normally that happens from either exceeding the rpm limitations of the converter or from excessive internal pressure in the converter.
I think you have been put on the wrong track here on a couple of things, so I suggest a mental reset on this. Leave all of what you were previously told aside as being either partly or completely wrong and start over fresh with accurate information instead.
The accurate info that we have right now is that your 95 5.0 2wd truck originally came with a 4R70W from the factory and that you had a failure that took out the thrust bearing on your engine.
Darrin
You might have to get in an odd position to see it and you might even have to use a mirror to get it, but that number would be darned handy to have right now.
Darrin
I know what kind of trans is in the truck. I found the receipt for the trans filter and gasket kit that I replaced last year. I went on the advance auto parts website and entered the number, it matched a 1991 E150 econoline van. The trans is an AOD (FIOD) transmission.
FYI, using the Advance Auto website for technical info is slightly less accurate than using Wikipedia if you want anything accurate.
But let's say that it might be an AOD by some weird happenstance. If it's an AOD there won't be a few things that I think that you will find if you get under your truck.
For example, on the drivers side of the transmission you won't see a sensor that looks like the one in the link below.
http://bcatransmissions.com/properalignment.jpg
If that is there then you absolutely do not have an AOD.
As soon as you see that sensor I am going to have to repeat my request for a mental reset. You need to forget what you thought you knew and start over. Otherwise we are wasting our time here.
Darrin
The following users liked this post:
It's just hard fighting that uphill battle when someone on either side of a problem gets their head hung up somewhere it shouldn't be and I am just as guilty of it as anyone else. That's why I like to start over and establish facts whenever there is a hint of that happening whether its on my end or someone else's. I have learned to drop back and try not to let what I think I know rule the process.
In this instance someone might have gone to all the trouble of putting an older transmission of a different type in your truck. I don't know for sure. What I do know is that I am not there to see it. I can't definitively say anything for sure because of that, so I have to rely on you to be the eyes and tell me what you see. I will do my best to tell you what you are looking for. Hopefully that pic helps.
By the way, in that pic you can also see the casting number I am asking for. It's to the right of the sensor under the Ford logo.
Let me know
Darrin
