help where is it at? shift control solenoid? transmission control solenoid
I was a transmission engineer for 19 years. I never heard of letting it run for 20 minutes before trying to drive it. Why would it need that? What would it do? If it isn't going to work in the first 5 seconds it sure isn't going to work in 20 minutes.
I think that you have a mechanical failure inside the trans. As you saw the solenoids are not the problem. Nothing electrical is going to cause this.
