F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-24-2009, 02:34 AM
Unhappy flashing overdrive off light
First off I want to thank this forum fo all it's help.
I've recently changed my transmission fluid but haven't drained my torque converter. This was the first time sense '99 that I believe the filter and magnet have been changed/cleaned. After the all was changed/cleaned I took it for a test drive. All looked fine, the truck shifted better than the day i bought it (1999 5.4L 4X4 f-150 supercab, automatic), then I noticed once once shifting into Overdrive that the Overdrive Off light on my shifter started flashing. Whats going on?
This didn't happen untill after I changed the fluid so is there a sensor or something that i missed?
It doesn't happen all the time, it seems to only flash once the engine has warmed up while driving. Any suggestions?
thank you for the help!!!
Old 10-24-2009, 03:41 AM
glc glc is offline
Vehicle: 2003 Ford F150
You need to go get the codes read. Simple OBD2 scanners can't read Ford tranny codes, you need to go to a dealer, a tranny shop, or a shop that has an advanced scanner.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-24-2009, 10:57 AM
Vehicle: 1997 Ford F150 5.4
Technically, he needs a scanner the supports "manufacturer-specific" codes which are those between P1001 and P2000. About half of the potential transmission codes are in this category.
These are not particularly expensive, but the cheapest scanners, often those used at the auto parts stores, sometimes don't have this feature. Usually scanners from around $150-200 and up will do the basic job.
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
1994 Taurus SHO 3.2/ATX
1989 Taurus SHO What a project! Retired at 249K.
1997 Ford F150 SC 5.4L New Work Truck
1998 Ford Contour Wifey's old daily driver
2007 Mercury Mariner AWD
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
