F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-17-2009, 04:10 PM
Question 1984 3speed manual trans
put new clutch,slave,master,throw out bearing,and pressure plate can put in gear try to start it and it takes off like clutch aint getting enough travel hey can any of you help with this problem
Old 10-17-2009, 05:20 PM
glc glc is offline
Vehicle: 2003 Ford F150
Is that an internal or external slave? Are there any adjustments that you can see? Did you thoroughly bleed the system? Did you replace the pilot bearing?
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-18-2009, 10:53 PM
[quote=glc;3928461]Is that an internal or external slave? Are there any adjustments that you can see? Did you thoroughly bleed the system? Did you replace the pilot bearing?[/QUOT
external slave and yes changed pilot and bleed thoroughly and the only adjuster is ao the master cylinder but that adjust the pedal
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
