F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-07-2009, 04:33 PM
Vehicle: 2003 Ford F-150 5.4L 4x4
Draining the Torque Converter
I will be changing the transmission fluid in my truck (03 4WD 4R70W) and am wondering how I can drain the torque converter, since I do not have the drain plug?
I have a copy of Mark Kovalsky's trans. service instructions, but they make no mention of whether the torque converter will be drained as well.
Old 10-07-2009, 06:22 PM
Vehicle: 2002 Ford E350
Yes, my procedure will change the fluid in the torque converter. It's the easy way to change it since your truck doesn't have a drain plug in the torque converter. The only other way to get the fluid out of the torque converter is to take the trans out, remove the torque converter, and drain it that way.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Old 10-07-2009, 06:53 PM
thanks, Mark. also, there are two lines on the side of the transmission, an upper and a lower. how can i tell which is the return line?
Old 10-07-2009, 07:13 PM
Vehicle: 2002 Ford F150
Start it up. Put your hand on the lines at the radiator and the first one that gets warm is the inlet to the cooler.
Roadie
2002F150LariatFX4Supercab5.4L
Old 10-07-2009, 09:48 PM
glc glc is offline
Vehicle: 2003 Ford F150
Unless you take it to a shop that has a fluid exchange machine.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 10-22-2009, 12:37 PM
Vehicle: 1997 Ford F250
Where do you find a copy of Mark Kovalsky's trans service instructions?
Old 10-23-2009, 11:34 AM
You can find the most up to date version here:http://www.thedieselstop.com/forums/...1/#post1564217
This version does not address the 4R70 family. The only difference is the total capacity is a bit less (consult your owner's manual, I don't have it) and the cooler lines on the trans are top and bottom, not front and rear. I also don't remember which one is out and which is in. Drive the truck and the hotter one is to the cooler. Remove the cooler of the two.
Mark
Old 10-23-2009, 08:49 PM
Vehicle: 1997 Ford F150
Quote:
Originally Posted by minimonster17 View Post
.... also, there are two lines on the side of the transmission, an upper and a lower. how can i tell which is the return line?
Do you have an aux trans cooler? If so, follow the line that comes FROM the rad to the aux cooler. It should be the bottom line on the rad. That means the upper line to the rad is the trans OUTPUT line.
I'd think in general, even if you don't have an aux cooler, the top line on the rad is going to be the trans OUTPUT line, right?
Well, that's the one I tapped into for my trans temp gauge!
Good luck with it all!
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
