F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 10-02-2009, 11:44 AM
Unhappy 2001 ford f-150 supercrew with no reverse and 2nd neutrals out after 2500 rpm
hi guys, was looking for some help i have a 2001 supercrew that has lost reverse and 2nd will neutral out after 2500rpm have the trans removed and looking for some help if anyone has seen this before. i understand that reverse is totaly mechanical? so what would cuase both reverse and 2nd to go?
Old 10-02-2009, 09:37 PM
Vehicle: 2000 Ford F150
Would it still neutral out with OD off? Did you try manual 1st and 2nd gear and see if they engaged?
The reason I ask is because there are two bands in the 4R70W. The reverse band is used in both reverse and manual 1st gear, but not 1st gear in drive. And the Overdrive band is used in manual 2nd gear, and for OD in drive.
So if those two work then its not a band.
Next question would be was it shifting really late from 1st to 2nd? Because you might have the same failure I had and maybe 2nd isn't second at all... I thought I still had 1, 2, and 3rd. In reality the tranny was shifting directly from 1st to 3rd, which is why the shift was so late.
So it would shift 1 then hold it extremely long and then jump into 3rd and i could cruise. This was only with OD off though. If I left OD on it would try to go into OD and neutral out. I also lost reverse at the same time, so if what I just said sounds familiar then at least I already know whats wrong lol.
You really shouldn't have taken out the tranny before asking questions for help because there's no way to test theories now lol.
- Erik
Old 10-03-2009, 01:29 AM
Vehicle: 2006 ford f150
sounds like maybe a broken reverse sun gear shell to me dont really know how to describe it look at the plantary at the big piece that goes in to it will have a weld broken and will turn not supposed to
Old 10-03-2009, 04:50 AM
Quote:
Yep, that's exactly what I was thinking. The same happened to me and that's why I'm currently rebuilding my tranny lol. That's why I described the symptoms to him. Great guess jhunt47
- Erik
Old 10-05-2009, 01:07 PM
found it!!!!
ya guys it was the sun gear shell i found it the day i posted the thread sorry. i found that the shell was spinning on the sun gear and from my past tranny experience i knew that wasnt right. so i am in the process of replacing it and putting the trans back together
Old 10-05-2009, 04:10 PM
Yeah, I had this happen to me about a month ago. I'm still rebuilding the tranny slowly. Interesting to see this happen to someone else, it must be a more common failure point than I thought.
- Erik
Old 10-05-2009, 07:43 PM
Vehicle: 2001 Ford F150
Quote:
- Erik
I have a couple of shells sitting around that spin free of the gear like that. It isn't uncommon.
Darrin
Old 10-29-2009, 12:01 AM
Vehicle: 2001 Ford F 150
Well chalk up another one. Last Friday left work, shifted in reverse mine popped and was sluggish backing up. Shifted to drive and was slow taking off. Next morning same thing happened when I left home. Drove about 2 miles and had no reverse or OD. In the tranny shop now my mechanic says broke planatary gear and it's not even been on the lift yet! 2001 F150 Screw KR 4 x 4
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
