4r70w 4r70e
4r70w 4r70e
i have a mfg 8/96 (97 4x4 4.6l supercab installing a 03 sc motor) 4r70w heard its last year before some major improvements and wondering about getting a newer 70w or 70e. which year would be better and what about the electronics same harness repin different harness different pcm?
yep they came with the 4r100, i wanted to upgrade the 4r70 keep the motor near stock and not race it.trying not to have to redo crossmember legthen shorten driveshafts but always open minded to ideas.
Thanks fx41
"If we treated the 2nd Amendment like we treat the 1st, we would have the right to bear nuclear arms by now."
"When the people fear the government, that is tyranny, when the government fears the people, that is liberty!"
Aint that the truth!!!
Thanks fx41
i love it, handles everything i throw at it. just buy a new trans cooler too, i chose a fan mounted model for extra cooling.
phil, i've talked to Darrin about that trick. for the most part it sounded like a matter of starting w/ a newer trans and rewiring its connector. obviously after rebuilding what needs be
The 4R75W will cause an issue with the output shaft sensor since the ring gear on them is different than the 4R70W. There will be clearance issues with the old sensor and even if you use the new sensor there is a different tooth count on the ring gear which will whack the shift schedule.
Honestly, strength wise there isn't any difference between a properly built 4R75W or any version of a properly built 4R70. Some vendors like to use smoke and mirrors to up-sell their product.
Darrin
Darrin
