F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-13-2009, 06:37 PM
Vehicle: 2002 Ford F150
Send a message via AIM to Typow07
Trannys slipping
So i just hit 115k and my tranny is statring to slip in 3rd gear, it started when it would shift into 4th gear and id slow down to 40 to 45 it would jump and not wana speed up, than jump into over drive as i gave it more gas. So now my question is, what do i do now? If im going to have to get a new tranny i want a very strong one. I herd one time that a bigger f series like a f250 hd will bolt up to my 4.6 is this true?
Old 07-14-2009, 04:30 AM
glc glc is offline
Vehicle: 2003 Ford F150
Have you ever changed your tranny fluid? How does the fluid on the stick look and smell?
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 07-14-2009, 08:44 AM
its full of bubbles, I purchased the truck at 70k and changed the tranny fluid right after I got it. I am planning on getting it changed on friday
Old 07-14-2009, 09:42 AM
Vehicle: 2003 Fast Screw
Quote:
Yes it will bolt up but there's a LOT more involved in swapping over to the 4r100 tranny.
You would need the trany and the computer out of the truck it came from to operate it. Also you would need the 4r100 flex plate,torque converter,trany wire harness,dash wire harness,cross member. Plus you'll need to have your driveshaft shortened and your exhaust rerouted to get around the bigger trany.
There may be things I forgot but it's a big ,expensive job.
A lot cheaper to have your 4r70w built stronger.If that's what you end up needing.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
