F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-12-2009, 07:15 PM
Tranny Trouble
well a month ago or so i was having some problems with my tranny i believe.....it wouldnt engage into gear unless i revved it up really high.....wen it was really bad i revved it up quite a bit and the driveshaft snapped....i put the driveshaft in today and i need to know wat the problem is...i have an 00 f150 triton v8 4.6 4x4.....it will go into reverse but will not engage into drive or 1 and 2...thanks
Old 07-12-2009, 09:15 PM
it also didnt start happening til the day that it broke....the tranny was fine before that
Old 07-13-2009, 05:56 PM
bump......could it be something hydrolic or something like a tranny switch....i know nothing about trannies
Old 07-14-2009, 04:31 AM
glc glc is offline
Vehicle: 2003 Ford F150
Is the fluid full?
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 07-14-2009, 04:55 AM
Vehicle: 2003 Fast Screw
If it's full of fluid and slipping that bad it's probably toast. Time for a rebuild.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Old 07-14-2009, 07:00 PM
yes its full of fluid......that really sucks ive only had this truck on the road for like 3 weeks total.....my stang got totaled cuz some pregnant lady macked into me wen i was at a dead stop doing 35.....ive had nothing but problems with cars lately lol....how much for a rebuild usually....the kits are around 300 if im correct right?
Old 07-14-2009, 10:59 PM
Similar Problem
I have had a similar problem on my 2004 F150 fx4 w/ 5.4 liter. I have had a problem with the engine revving up and then popping into gear. It was really bad today on my way home from work and today my engine light came back. A couple weeks ago I had the dealership do the following work:
- Replaced two cylinder coils
- Replaced cylinder head sensor
- Replaced all spark plugs and wires
- Replaced fuel filter
I spent a ton on all of this but I'm just about ready to throw in the towel on this truck. Any suggestions on what the slipping could be? When it did it in the past I replaced the fluid and it seemed to help quite a bit. I just checked the transmission fluid with the engine hot and it looked like I was more than full and the fluid looked fairly red too. I would appreciate any help.
Thanks,
Daniel
Old 07-15-2009, 08:44 AM
Vehicle: 2001 Ford F150
For whatever reason it sounds like the forward clutch isn't engaging until it gets a lot of pressure. It could be a valve body issue, a pump issue or an issue in the forward clutch. Perhaps a sticking check ball on the forward drum, but that seems a little far fetched.
The only things you can address without taking the whole transmission out of the truck are fluid level and the valve body. Other than that it's probably time to pull the transmission.
Darrin
Old 07-15-2009, 03:26 PM
Follow Up
Thanks. I don't know if this has anything to do with it but I took it into Autozone this morning and had the codes read for the check engine light.
This is what it gave me:
Code: P0420
Catalyst efficeincy low-bank 1
Explanation
The oxygen sensors monitor the catalytic converters ability to store oxygen.
Probable cause
1. Catalyltic Converter defective (failure possibly due to #2,3, or 4)
2. Engine misfire or running condition
3. Large vacuum leak
4. Engine oil leakage into exhaust-valve guide seals, piston rings
When I left Autozone on my way to work my dash said "TRANS FAULT" and the o/d off symbol was blinking. This was the first time it did that. I started my truck and drove it around the block but it hasn't come back on. My tansmission levels seem alright and the color is red but not bright red and it looks dirty to me.
Thanks,
Daniel
I can get it to go into gear more easily by manually shifting from 1,2 then putting it in drive.
Old 07-15-2009, 05:54 PM
Just got back from the transmission shop
Just got back from aamco transmission and they said around $2000.00 to rebuild it. Called the dealership and they are saying anywhere from $1500 to rebuild and could go up from there up to $3500.00 for a new tranny. Does this sound right?
Another thing. Could the check engine light issue listed above be due to the transmission causing the engine to rev really high? Man I hope it's not another separate issue.
Old 07-15-2009, 07:28 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
Autozone's code box cannot read the majority of transmission codes. As for the rebuild every Aamco rebuild I have seen had the cheapest garbage frictions made in them. The OEM frictions are far superior. I wouldn't trust the aamco rebuild to last 2 years. If the dealer does it right you should expect 5-7 years of reliable service from it. I suggest talking to a few small transmission shops. They usually care more and use better parts from what I have seen. Aamco gets paid from the home office for warranty work, so it doesn't bother them. Small shops pay out of pocket so they find it cheaper to do it right the first time.
Alan
Old 07-16-2009, 12:30 AM
Vehicle: 1999 Ford F150 4x4
I second the small shop or dealership route. But don't just pick someone out of the phone book. Get references.
Another option, if you want to/can R&R it yourself, is to talk to a couple guys on here who rebuild. Some shops will build you one, then take your core on trade, others, you ship them yours, and they build it and ship it back.
Andy
Old 07-16-2009, 12:57 AM
Vehicle: 2005 Ford F150
Send a message via Yahoo to jrohrigj
transmission rebuild cost me around 1950.00
Old 07-16-2009, 01:27 PM
glc glc is offline
That code is just a bad cat. Does not affect how it runs unless the cat is plugged.
You need a high end code scanner to read tranny codes. Autozone's can't. When the OD light flashes, it sets a tranny code.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
