F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-07-2009, 06:43 PM
Vehicle: 1998 Ford Expy 5.4
Send a message via AIM to Camarothatcould
City driving trans temp
I dont like how hot the trans gets when in town. This is the first summer I have had my trans guage and it can get up to 210 just city driving.... Should you knock it out of OD while city driving???
I have the external cooler, I was thinking about a fan on that thing....
yes I do this daily
Old 07-08-2009, 12:47 PM
Vehicle: 2001 Ford F150
I have 2001 Supercrew - 5.4 and the highest I seen since installing the ScangaugeII (in April) is 170 degrees in the city. It hasn't been that hot here yet - nor have I pulled any sizable grades yet. But, I would fussing about 210 degree reading.
The location of the sensor can make a difference in the reading. From what I understand, the scanguageII get's it's reading from the valve body - not sure if that is the hottest place in the fluid cycle or not?
Old 07-08-2009, 02:29 PM
Vehicle: 1997 Ford F150
No, that would not be the hottest the fluid is getting, but it's the temp of what the fluid is starting at before it gets to the torque converter.
The trans output line to the rad cooler would be the 'hottest' the fluid itself has gotten AFTER it's done it's thing in the trans.
That's where I get my trans temp from with my aftermarket gauges.
I can't remember if Camaro has aftermarket gauges or not?
He does have oversize tires (33") and 3.55 gears and I don't know if he's re calibrated his speedo/odo yet with a new VSS gear (97-98's use gears for it. 99 and up use the comp)
If he's seeing 210 on the output side, that's not so bad, as long as it cools down when he gets some air flowing again. It should run around 180*-195* constant in the heat of the day going down the hwy. (well, that's what mine does towing or not)
I've seen 210* in stop and go, but once you get moving, it comes down again.
If you do a lot of city driving, then a fan might not be a bad idea....
I wonder if he has electric fans too? Even at idle with my mechanical fan, I get a good amount of air draw thru the grill and that includes the area where my factory aux trans cooler is located...
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Old 07-08-2009, 02:32 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
hes still on stock mechanical fan
Old 07-08-2009, 03:41 PM
yes stock fan.... I have B&M trans temp gauge... I have my sender unit on the HOTTEST flow of fluid, right before the radiator... so I know its right out of the converter... I just hate seeing it so high.
Also, tomorrow I should be getting to my VSS gear... I have to pull mine first to see ho wmnay teeth, than shop around for the right one
yes I do this daily
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
