F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-06-2009, 04:20 PM
4R70W Transmission: Can the Filter fall off?
Greetings,
I changed the transmission filter for my 2001 F150 with a 4R70W transmission and whereas the original filter in the tranny was snug against the valve body, the replacement filter I bought from Autozone seemed to sag a bit after plugging it into the valve body. I'm concerned that the sagging might indicate a not-so-tight fit and I'm worried if the filter could actually fall off the valve body.
Anyone ever hear of the filter falling off the valve body? I'm thinking perhaps the clearances in the pan are such that the filter doesn't have the room to fall downwards off the valve body but I thought I would ask.
thanks.
Old 07-06-2009, 11:16 PM
Vehicle: 2006 Ford F150
It pretty much sits on the pan...so it can't really fall off as such....i just changed mine today.
Old 07-06-2009, 11:22 PM
Vehicle: 2002 Ford F150
You may not have pushed it in far enough.
The only transmission that I personally know of where the filter fell off is my friend's 77 Olds Cutlass back in the 70's. He bought the car new and I think it was the original filter. His transmission started slipping when the filter came off. The dealer replaced the filter and the trans worked fine.
Roadie
2002F150LariatFX4Supercab5.4L
Old 07-07-2009, 03:55 AM
Vehicle: 2007 Ford F150
It could just be that your aftermarket part from Autozone does not fit as well as an OEM part. Next time, try to get your hands on Motorcraft.
Old 07-07-2009, 06:11 PM
Exclamation
Did you remove the old filter o-ring from inside the valve body? Sometimes upon removing the filter the o-ring stays behind.
2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
Injection is nice but ide rather be Blown!!!
Old 07-12-2009, 10:19 AM
Vehicle: 2001 Ford F150
Quote:
That is a GOOD fyi by the way.
Darrin
Old 07-12-2009, 01:57 PM
If I were you, I would drop the pan again and make sure the filter is installed properly.
Roadie
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
