F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-29-2009, 02:29 PM
Vehicle: 1998 ford F-150
Send a message via AIM to ssj4shane
torque converter info plz
What are the spec and size on the oem torque converter for 5.4 with 4r70w ?
and would useing a torque converter out of a newer 4r75w be better ?
My torque converter took a **** on me and wiped out the tranny
just got rebuild today and now i need a new torque converter.
f150
98
4.6 to 5.4 swaped
4r70w
4x4
Old 06-29-2009, 06:40 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
98 5.4 specs
Pump is furnace brazed, low stall. Stator has phenolic (plastic) spacers on both sides. Turbine hub rivets may or may not be solid. Standard o-ring type seal. Friction measures 10inch ID by 11&1/4 OD with 3 grooves for faster smoother apply. Turbine is not brazed.
04+ 4r75 specs
Pumps are all furnace brazed most are medium stall.
Steel stator cap on pump side with bearing. Solid teflon sealing ring. Friction measures 10 inch ID by 10.5 OD has 4 grooves, Rivets are solid. Turbine is brazed. All full size truck converters until the newest transmission are considered 12 inch units.
Alan
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
