F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-27-2009, 05:52 PM
Vehicle: 1988 Ford F250
Exclamation My Truck dies when i put her in gear
Hey Guys, I have a 1983 Ford F150 with a 351w and a C6 auto 4x4 trans and it dies when i put it in any gear but will idle in park or neutral, I have replaced the torque converter and it didn't help a bit please help
Old 06-27-2009, 07:19 PM
glc glc is offline
Vehicle: 2003 Ford F150
I think you are looking in the whole wrong place. That's a problem with whatever controls the idle speed on that engine, not a transmission or torque converter problem.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-27-2009, 07:23 PM
Quote:
I have adjusted the idle speed to about 1200 and no change i think the tranny is done for but i don't know.
Old 06-29-2009, 02:15 AM
Vehicle: 1989 ford F150 4x4
you have a stuck on torque converter lock up valve. if you pull the valvebody off trans and inspect the valves you will most likely find the spool stuck in its bore to the apply side. it is also possible that the gasket is damaged, or valve body is loose allowing a cross feed to tq circuit from another source.
i unfortunately dont have a picture of a c6 valve body handy. there is a few other possible areas that could cause this, but are less likely than the spool, of gasket/valvebody. if the pump has a crack into the stator support it can leak high pressure oil into the tq causing the lockup, but generally the pump fails very soon after this happens.
good luck.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
