F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-25-2009, 03:22 PM
Vehicle: 2005 ford f150
Send a message via AIM to azmidget91
any tips on removing a trans
out of a 05 f150 with the 5.4 4R75E, the top passenger side bolt looks like it will be a pita to get to....
my gallery on photobucket
Old 06-25-2009, 04:30 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
I use a 4ft long extension and a snap-on swivel socket.
Alan
Old 06-25-2009, 04:34 PM
Vehicle: 2005 Ford F150
Sure would help to have a transmission jack.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
Old 06-27-2009, 10:00 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
If you are doing it in the driveway you will need to lift the truck high enough for the transmission to pass under the frame. As for the bolt, I also use a 4 foot extension and a swivel joint. Air tools make is sooooo much easier.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 06-27-2009, 09:12 PM
Ahh, the infamous bellhousing bolts...
Well, you need lots of extensions, 6"-3' and some assorted swivels.
As for air tools, break all the bolts by hand then you can get out the air.
Try to use 6 pt. sockets. As my buddy Jeff would say, "If you strip one of
those bolts it'd truly be a greek tragedy."
Just find a place further back underneath the truck where you can see the bolt,
and try to get a socket on it with extensions.
Old 06-29-2009, 01:46 AM
Vehicle: 1989 ford F150 4x4
The easiest way to get the upper bellhousing bolts is to let the trans and t-case hang down, by removeing the trans cross member first. undo the upper bellhousing bolts first, then you can lift up the trans and remove the remaining ones after. dont let the trans hang down much more that 4" and the rear trans mount or you risk damageing fan or shroud. tho i must admit, in all the years i removed trannys at ford, letting them hang all the way down, i have only ever broken a couple fans, and they were in explorers.
good luck, and if you need more specific info on individual parts, let me know, ill be glad to help.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
