F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-25-2009, 03:05 PM
Vehicle: 2004 Ford F-150
Send a message via AIM to Tyler33
Vibration felt when converter unlocked
I thought it was a u-joint at first but I only feel the vibration when the torque converter is unlocked. It was pretty obvious when I was pulling a trailer, nothing too bad but noticeable on the highway.
Should I take it in on extended warranty or just change the tranny fluid? Will a pan drop do the trick or does it need to be flushed? I'm at about 56k miles on an 04 4x4.
Old 06-25-2009, 03:16 PM
Vehicle: 1997 Ford F150
That does sound like the "old fluid shudder" issue, but I thought it happened more when the TC locked?
In any case, when was the last time you had a tranny service done?
An easy 'bench test' of the fluid is taking your dipstick and dripping it on a paper towel and if you have some new fluid, drip some next to it and compare..
If you've never done even a pan drop to date, then you may want to have the service done that circulates all the old fluid out while putting in new fluid..
I have an older trans that has the TC drain plug on it, so I had that done when I first bought the truck with 63,000 miles on it and I've done pan drops every year since then.
I tow a TT during the summer time and I put on about 15,000 miles a year as a whole on the truck, so it's cheap preventive maintenance IMO..:thumb:
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Old 06-25-2009, 04:52 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
On early model units the impeller blades liked to come loose. The way to see if that is the issue is get on and off the gas at about 20mph in 2nd. They will give a chingy/changy noise as you get on and off the throttle. In the later years (03+) the fins are furnace brazed. That eliminated the problem. The next issue inside the converter that likes to cause that problem is the rivets on the turbine hub. Again in the later years ford revised these to prevent the problem. Early models were small head and hollow. The late ones have a huge head on them and are solid. Your truck should not have any of those issues but if it is a 4.6 (or 4.2) in 03 it may not have been updated yet. 5.4's got updated way before that.
Alan
The reason I say 03 is because it is possible to have an 03 trans in an 04 truck.
Old 06-25-2009, 07:37 PM
Mine is a 2004 (not heritage) with the 5.4 liter. I'm not sure if the fluid has been changed, I bought the truck used and have put about 1000 miles on it.
Old 06-25-2009, 08:04 PM
I am doubtful the problem is in the torque converter on that unit.
Alan
Old 06-26-2009, 12:45 PM
Quote:
Alan
Care to elaborate on that? All I know is there is a light vibration/shuddering when the torque converter is not locked. Once it locks out everything runs smoothly.
Old 06-27-2009, 12:32 AM
I tried to explain, but basically the issues that would cause this are mostly eliminated in that unit. It may sound dumb but it could be a matter of rpm and could be something as simple as a puley or bearing in one of the components on the front of the motor. I had an alternator make a terrible vibration between 2200 and 2500 rpms. When the converter is locked the drivetrain may be absorbing it. Does it do it sitting still?
Alan
Old 06-28-2009, 01:02 PM
Nope no vibration when sitting still and revving. I can't really tell if it does it in the lower gears but on the highway its pretty noticeable. If it were rpm based then I should get vibration at high speed because I'm running the same rpm that's giving me vibration when the converter is unlocked. I had it up around 100 yesterday and it was smooth as can be.
Thanks for the help.
Old 06-28-2009, 10:03 PM
I'd have the wheels ROADFORCE balanced before I would go any farther.
Alan
Old 06-29-2009, 02:30 AM
Vehicle: 1989 ford F150 4x4
has the codes been pulled from the pcm? any evap codes? slight vacuum leaks in the evap can cause tip in engine studder/vibrations.
Old 07-14-2009, 02:47 PM
Since I first posted this question I have lifted my truck and added larger wheels and tires. The vibration is more pronounced in first gear now when I'm accelerating hard. It goes away at higher rpms in first and is less noticeable in second gear. Tires can be eliminated as I have brand new ones now. I still notice the vibration when the torque converter unlocks at highway speeds but it's less noticeable than when it's in first gear under hard acceleration. Any more ideas? I still have not had the pcm codes checked.
Old 07-14-2009, 03:56 PM
It is possible that the balance weight came off your converter. If it was one that used a heavy weight and it came off you will get a vibration from it. The extra weight of the lockup piston applied to it instead of rotating at a different speed could make it go away. If you pull it out and get anywhere near cincinnati I will gladly spin it on the balancer for you, but I am unsure if that is your problem. Just a guess here.
Alan
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
