F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-23-2009, 09:05 PM
Vehicle: 2007 Ford F150
Flush Transmission at 30K for $189?
The dealer wants to do a transmission flush on my 2007 FX4 at 30K miles. Their price is $189 which includes the 15 quarts of trans fluid. I tow a 4000 lb boat with my truck on occasion, but it is used mainly for driving around town and when going on vacation.
I do not mind spending the money, but I want to make sure it is a good practice and the price from the Ford dealer is within reason. I do not want to do it myself.
Thanks,
KR-Texas
2007 FX4 Luxury - Dark Shadow Gray
3" AF1 Intake, True Duals w/ MagnaFlow, X-Pipe and 22 x 3.5 Black Tips, VMP Tunes
2" AS, 3" ReadyLift, SuperSpring Helpers, 18x9 Rockstars, 33x12.50 Toyo MTs
Black Boards, Black Badges w/ DSG Inlays, DSG Overlays, HD Tails, Smoked Third Light
FX4 Sticker Delete, Tint, Fold-a-Cover, BedRug, Stealth Bulbs, Alpine TV w/ DVD
Old 06-24-2009, 12:16 AM
Vehicle: 2002 Ford F150
That's a normal price. If you tow changing at 30k is normal too.
Roadie
2002F150LariatFX4Supercab5.4L
Old 06-24-2009, 10:28 AM
That is what my dealer wants as well to drop the pan and empty the TC. Seems to be the standard charge and for sure needed if towing in my opinion.
Old 06-24-2009, 10:48 AM
Send a message via Yahoo to risupercrewman
Thats the standard charge, I had the same service done when I hit 30K, I do tow 5000LB loads from time to time. It's a good idea to have it done every 30K!
Old 06-24-2009, 03:49 PM
glc glc is offline
Vehicle: 2003 Ford F150
You can probably find someone that can do it cheaper, but the basic principle of doing a full fluid exchange at 30k is good.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-24-2009, 04:03 PM
Vehicle: 2001 Ford F-150
Send a message via MSN to JD790
If you have more than 1 dealer in your area call around and get some prices. We charge $159 for the complete flush. Definitely recommend every 30k miles.
Thanks to Bombo at ScreenFx for the sig!
Current Truck - 01 Supercrew Lariat Off-Road Edition 6 + 3 Lift 38" Toyos 4.88's Etc.
Suspension Build Thread/Specs/Pics Photo Gallery
Previous Truck - 07 XLT Supercrew - 6" PC Lift 35" KM2's PC Wheels Edge
Specs Photo Gallery Mudding Pictures
Old 06-24-2009, 05:57 PM
Vehicle: 2007 Ford F150,f250
ive had my powerstroke done at the dealer and if i remember correctly it was only around 100
Old 06-25-2009, 12:41 AM
Thanks to all who replied. I let them do it for the price they quoted. My truck has 29,900 miles, so I figured that was close enough.
KR-Texas
Old 06-25-2009, 12:51 AM
Vehicle: 1996 Ford Bronco
Yea get it done every 30k. Don't forget your air filter (if still stock) and fuel filter every 30k.
Old 06-29-2009, 12:39 AM
I have the AF1 CAI and I just changed my fuel filter at 26,000 miles, so I should be good to go.
Thanks,
KR-Texas
Old 07-03-2009, 11:15 AM
Vehicle: 2005 Ford F-150HD
Next time save some money and do it yourself.
Drop pan, change filter, clean magnet, (install drain plug or pan with drain plug to make the next time easier), refill trans with the amount of fluid needed to fill pan only (varies according to year and trans), find trans outlet cooler line at radiator, disconnect and run hose (or an extension you add) into bucket, have the remaining amount of oil needed to a full change plus a couple extra layed out and ready to pour into dipstick tube via funnel, have assistant start engine, pour fluid in at the approximate rate it's coming out into the bucket (approximately 1 gallon per minute on a 4R75W), continue until you've used all the fluid but one quart, shut off engine, reconnect cooler line, restart engine, check for leaks and top off trans as necessary. If the fluid has gone dark, it's easier because it will change color and tell you all the old has been flushed.
For normal maintenance, this is a perfectly adequate way to do it. There may be some advantage to a professional flushing machine on a high miles trans that has never had a fluid change, but the cooler line "home flush" does a great job when you drop the pan. I wouldn't do it without dropping the pan. If you've seen the magnet all covered in iron fuzz, you'll know why.
The primary reason to change the fluid is to remove wear metals. According to my sources, the Ford filter in the pan is a 100 micron unit. Most of the wear particles in the trans are between 5 and 80 microns in size, so they circulate freely. Most of the wear metals are iron and copper (iron from planetaries and copper from the clutches and converter clutch), and these two elements can cause the oil to oxidize more quickly.
I'd recommend adding an inline trans filter too, which will extend your service interval significantly. Ford offers a rebadged Magnefine in a kit with all the fittings you need to install it, plus instructions (the service manual has more exact instructions for the F-150). It's # XC3Z-7B155-CA. The Magnefine is a 35 micron filter with a magnet and flow director. Tests show that 51 percent of the wear metals in a trans are ferrous, and the Magnefine will get almost all of those with the magnet. It passed all of Ford's OEM qualifications and is used primarily with reman transmissions. When a trans fails it dumps lots of junk into the coolers. Plus, reman trans are never as clean as newly built (which aren't all the clean either), so all that junk goes right back in to kill the trans. The install tech is supposed to flush the cooler, but some are flat-raters don't and say they do, so the failure rate for remans was pretty high until Ford started putting the Magnefines on with a remain trans. It goes on the return line to catch all the junk before it goes back in via the lube circuit.
I changed the ATF in my '05 F-150 at 11K miles just to clear out the manufacturing contaminants as well as the break in stuff (the magnet had a lot on it). I then learned about the Magnefine and installed it at 15K. I did before and after particle analysis on the oil and in just 2200 miles the ISO Cleanliness Code (Google it) dropped from 15/14/12 to 13/12/9... a major drop in contaminants.
Racor also makes a kit with a spin-on 10 micron (absolute) filter and I installed one on my '86 F-250. It dropped the ISO Code from 16/15/13 to 15/14/12 in just 423 miles.
It usually takes about 5000 miles to drop the contaminant levels as low as they will go according to the efficiency of the filter
2005 F-150HD XL 4x4 5.4L 3V, 8200# GVW, 4.10:1,
Rancho Quik Lift, Edge Programmer, Dynomax 3-in Exhaust, AEM Brute Force Intake, 285/70R-17D **** Cepek FC-II
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
