F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-23-2009, 11:10 AM
Vehicle: 2005 Ford F150
Cool Do I have a transmission problem?
I have a lifted '05 Supercrew 4x4, 5.4, auto, 4:56 gears, 35" tires, with 75K miles. I have never had any transmission problems .
I normally get 11.5-12 miles per gallon. When I tow my 6000K boat, my milegae doesn't change much, maybe 10 mpg on a bad day. Last time I towed the boat home from the river, a 4 hour drive, I got 6 mpg.
I am perplexed about this. A friend suggested my tranny may need a rebuild, although I have had no slipping issues. I am open to suggestions.
One last thing, I have not had a transmission service or plugs or wires replaced on this truck before. At 55K, the dealer said everything was good and not to worry (tranny) until 75K. Well here I am....
I hate to give away stacks of hundred dollar bills to the dealer if not warranted.
[img]
http://www.f150online.com/galleries/pictureview.cfm?pnum=147483&anum=9659[/img](Not linked)
Old 06-23-2009, 01:20 PM
Vehicle: 1994 F150
I would start with the cheap, obvious possibilities; fuel filter, air filter, plugs, wires, injector cleaner...any codes?
Bill
'94 XLT Scab 6' Rough Country, 33' BFG TA/KO's
Old 06-23-2009, 03:25 PM
glc glc is offline
Vehicle: 2003 Ford F150
That doesn't use wires, it's a COP engine - coil on top of each plug.
The 05's had injector issues, yours may be leaking.
If you tow, you should change the tranny fluid every 30k.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-24-2009, 08:02 AM
Vehicle: 1997 Ford F150
Get a can of Mass Air cleaner and spray it down good. If you are using a K&N airfilter or equivlent go easy on the oil. If not replace your paper air filter at the same time.
Old 06-24-2009, 08:49 AM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
i agree about the injectors, worth looking into before they end up trashing the block
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
