F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-19-2009, 02:44 AM
5spd problems shifting?? HELPPPP
i have a 1998 ford f-150 with a 4.2l 5spd some times when i push the cluch down and shift it does fine other times its hard to get into the gear iam trying to shift to i have to play for a second to find the gear whats the problem????
Old 06-19-2009, 03:29 AM
glc glc is online now
Vehicle: 2003 Ford F150
Is the stick sloppy or is it just being balky trying to get it into gear? Is it hard to get into 1st when stopped when you step on the clutch? How far up the pedal travel is the clutch engaging? How many miles on the truck, and is it the original clutch?
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-19-2009, 04:20 PM
Quote:
its being i guess balky its hard to get it into any of the gears... 1st is hard to get into gear when stop and when moveing. If you push and play and wiggly it will go in but is hard..it seems like half way down. 95,000 The guy told me that the clutch was replaced not long ago....
Old 06-19-2009, 04:38 PM
Vehicle: 2006 Ford F150
Sounds like a clutch problem to me, but I could be wrong. Your syncros could be going out...
Old 06-19-2009, 07:42 PM
Vehicle: 2002 Ford F150
I think a lot of people complain about the shift of the manual transmission. I know the Mustang stock shifter left a lot to be desired. My son replaced the stock shifter on his 04 GT with a B&M shifter and there was a world of difference.
Roadie
2002F150LariatFX4Supercab5.4L
Old 06-20-2009, 02:06 PM
Balky like that is often a sticky pilot bearing. Easiest way to get it into 1st is this:
When coasting down to a stop, put it in neutral and release the clutch. When you are almost stopped - doing about 2 mph - step on the clutch and it should slip right in.
Old 06-20-2009, 06:56 PM
JMC JMC is online now
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Check the fluid level in the clutch reservoir. A low level indicates a leak. Try bleeding the clutch.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 06-20-2009, 07:04 PM
Regards
Jean Marc Chartier
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
