F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-19-2009, 01:31 AM
Vehicle: 1999 Ford Expedition
should i change my fluid?
I bought my Expedition (5.4, 2wd) about a month ago. It had 188k miles. The PO (who is also the original purchaser of truck) said he has NEVER changed the fluid in the truck. It doesn't smell burnt but when it shifts into OD it shudders about like when you run off the side of the highway on those grate things that are there to get your attention or wake you up. One place says don't think about it. One place says do it.
What should I do? Will a fluid change stop the shudder? I put stop slip in it at the advice of a ford tech I know. Nothing. A shadetree mechanic I know said a fluid change will stop the problem.
Old 06-19-2009, 01:49 AM
glc glc is offline
Vehicle: 2003 Ford F150
Change it. Drop the pan, change the filter, and also drain the torque converter. If it doesn't fix it or it gets worse, get a rebuild.
Are you sure the shudder isn't a low grade misfire? At 188k, it could probably use a new set of plugs and cops.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-19-2009, 09:12 AM
The tech I know told me it was definately in the tranny. He said it felt like the clutches in the torque convertor were slippin?
Old 06-19-2009, 01:11 PM
glc glc is offline
If that is in fact what it is, a complete fluid change is your only chance to avoid a rebuild. It's not going to get any better by itself.
Old 06-19-2009, 01:39 PM
True. Just didn't want to do more harm than good
Old 06-19-2009, 01:59 PM
Vehicle: 1997 Ford F150
The condition of your trans is what it is after 188,000 miles of churning around in the same fluid from day one... Hopefully, the level is still good? Wonder it the dipstick was ever checked?
The shudder comes from the fact that there is old fluid in the system and it does not have the same lubrication properties as newer fluid would have.. When the TC 'locks', this is when it's essentially like a manual trans and a clutch plate.. The old fluid has no lubrication properties (or not enough) to allow for the locked condition, so it's like when you bog down a manual shift trans... You get a shudder...
I'd drain the pan and replace the filter and hopefully, you have a model that has a drain plug on the TC and you can drain that. Fill with just your ordinary Ford spec trans fluid and hope for the best!
I've got 198,000 miles on my trans (E4OD). I did a full drain of it when I first got the truck with 63,000 miles on it and then I've been doing YEARLY service pan drops ever since. Sure, it's only 6 qts with a pan drop, but doing it yearly, keeps it fresh enough for me and I do tow a TT with it in the summer time and my fluid is nice and clear and red each time...
Buying a used vehicle is a 'crap shoot' no matter what the miles are on it, so just take what ever happens with a grain of salt and if you weren't prepared to do some major mechanical work when you bought it, then?????
Good luck!
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Old 06-19-2009, 02:02 PM
Thanks! I will go ahead aned do it and hope for the best!
Old 06-19-2009, 07:32 PM
Vehicle: 2002 Ford F150
The torque converter shudder is fairly common with the 4R70W. Replacing the fluid usually stops the shudder.
I had a 95 MarkVIII with a 4R70W tranny and it was very common on those cars. A fluid change fixed mine.
Roadie
2002F150LariatFX4Supercab5.4L
Old 06-19-2009, 07:34 PM
So that's the tranny in mine?
Old 06-20-2009, 02:08 PM
glc glc is offline
What is the trans code on the door sticker?
Old 06-20-2009, 07:31 PM
Here is what is on my sticker
Wb 119
Brk 4
Int tr f2
R 8
Axle 17
Tr E
Spr 39
Old 06-21-2009, 08:20 AM
glc glc is offline
You have a 4R100.
Old 06-21-2009, 11:51 AM
Is that a good tranny?
Old 06-21-2009, 05:12 PM
glc glc is offline
It's better than a 4R70W.
Old 06-21-2009, 06:17 PM
Vehicle: 1999 Jaguar99 F-150
Good luck!
Mitch
If your transmission was built after August 2001, you don't have a drain plug in the torque converter.�
Gold Styleside
1999 XLT
Supercab 5.4
Flowmaster#70 Series,
Pioneer 7400mp.Rockford Fosgate
400a4 Amp.MTX-5000
Dual Eight's Sub.
Uniden Radar Detector,Billet Grille
A.R.E. Fiberglass tonneau cover,
Black Tinted Window's,
Super Chip
[HAVE FUN]
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
