F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-15-2009, 01:20 PM
Vehicle: 1997 ford f150
Vacuum plunger to engage 4X4 97 F150
How does the vacuum plunger attach to the bracket on my front diff. I lost 4X4 and wanted to check it out. Pulled the plastic cover and and everything is frozen. I see the plunger, a boot and the lever going up to the top of the diff but everything is stuck. What is the best thing to do.
John
Old 06-16-2009, 01:21 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Lots of penetrating oil to start. Soak it good. The Vacuum actuator motor, that is what the plunger is called, has a brass fitting that slides into an ear in the axle tube. It is most likely seized. Pull the boot out of the way the and release the e-clip. Try to pull the actuator out of the ear. Here is a picture of what happens if you hit the ear with a hammer.
I should have used more penetrating oil and less hammer. The penetrating oil might be enough to free up the rod in the actuator so give that a shot first.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
