F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-15-2009, 09:29 AM
Vehicle: 2006 Ford F150
Adding a fan to stock trans cooler??
I have a 06 F150, with the 5.4, and 4R75E trans with the stock trans cooler.
While pulling my 30ft trailer trans temp is 205-238Fpeak. 150-170 is normal range.
I was looking at the Troyer cooler to add inline after the stock cooler.
http://www.troyerperformance.com/cgi...gno=PPI-ATCKIT
But then got wondering if it would work if i just bought one of their 10" fans, with the 180-170 thermostat, and installed it on the stock cooler??
Has anybody tried this?? Can't see why it won't work...but thought i'd ask before i order.
Thanks.
Old 06-15-2009, 10:31 AM
Vehicle: 2003 Ford F150 FX4
The stock cooler on your model is pretty large (if you have the towing package). A dedicated fan for it would definitely help and then you wouldn't have to **** around changing the trans lines either.
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, True Duel Straight Pipes With X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
Old 06-15-2009, 10:35 AM
Or what about installing two 8" fans on stock cooler...but that would cost $212 plus shipping....which when the cooler and fan are only $280 plus shipping.... so probably worth going that way if your only going to save $68 ?? I'm not sure if the stock cooler and even 2 fans would be enough? Although i'm not sure how much airflow the stock cooler gets where it is....fans may do the job?
Old 06-15-2009, 11:21 AM
Quote:
Yes i do have the tow package...so it is a fairly large cooler. And yes that was my same thoughts...more connections meens possible leaks....and more hassle.
Old 06-28-2009, 04:00 PM
Vehicle: 2008 Ford F150 FX4
I am having the same problem towing my 27' camper, just ordered the troyer cooler hopefully i will be putting it in next weekend.
Old 07-02-2009, 12:45 AM
Vehicle: 2007 Ford 150
Quote:
If you could let us know how it works out for ya. As I have been looking at it for a while now. I'm in the same boat as you guys. I am hoping with this and the troyer vavle body and larger oil pan the trans will keep temps down.
Old 07-06-2009, 10:33 AM
I'm just installing the Troyer kit now.....I'll be hooking on my trailer on Wed....so i'll let u know how it works.
Old 07-07-2009, 09:21 PM
Please let me know how it does! LOL Tranny is next on the list and going to add the Troyer trans cooler and valve body along with a larger trans pan! Keep me updated please.
2007 Ford F150 "The Race Truck"
Old 07-09-2009, 06:10 PM
Vehicle: 1998 Ford Expedition
It is possible to add two or three 4" Computer Fans to your cooler. When used in a "Pusher" configuration they can work very well. Pusher meaning mounted to the front of the cooler; away from the radiator side. Radio Shack does sell a suitable fan for cooling computer cabinets. These are not the little clip on fans used for u-Processors that have little heat sinks attached. They are what we used to call "Muffin Fans" that are around 5-6" box square.
There are two such fans mounted on my transmission cooler that I added by default. Here is the rub; mine are connected to a controller unit IFB.
I designed and built it out of spare electronic parts and therefore its not available in a store.
If you do decide to add such fans you can safely attach both fans to the cooler, and than supply power and ground to them from an accessory or accessories circuit ran from off the engine. Since both fans are 12V, and have negligible current (>1Amp. ea.) it shouldn't be too hard. However be careful with your polarity when making such connections (+12V) is the red lead for such fans available from Radio Shack or similar. Make sure that your wiring is "Mil-Spec", and weather tight and use wire capable of being exposed to weather. I don't have pictures since I didn't think it would have been of interest.
SAE, Society of Automotive Engineers
AES, Audio Engineering Society
MACS, Mobile Air Conditioning Society
Old 07-09-2009, 11:00 PM
I got my troyer tranny cooler all in, I ended up leaving my stock one in and and adding the troyer as a secondary cooler. I will be taking my camper to florida next week I will let you know how it does.
Old 07-13-2009, 12:53 PM
Vehicle: 1999 Ford F150 4x4
I may be missing something, but the computer fans themselves would not be weather/water resistant?
I'm looking to add an SD cooler to mine, and was considering adding a fan, too, while I'm at it. Wondering if there's a junkyard solution? Motorcycle radiator fan, maybe?
Andy
Old 07-13-2009, 01:46 PM
Quote:
Andy
I have found with my SD cooler that a fan is not necessary. It mounts in the middle of the rad at the top rad support so it gets great airflow both from driving and from the truck fan pulling air through the rad. When I get enough time I have to put on the Troyer Efans and I am hoping that they pull even more air through it.
Old 07-13-2009, 03:00 PM
Thanks, Griz. I was concerned about low-speed effectiveness, but didn't consider the engine fan pulling air through.
Andy
Old 07-14-2009, 02:49 PM
Well i just drove over 700 miles pulling my trailer with a bike in the back...about 7000 lbs. Troyer cooler worked great. Max TFT i saw saw was 200 on a long hill. Ran in the 175 range most of the time. But was down in the 150-160's some times.
I left in my stock cooler and plumbed it into the return line as they suggest. Well worth the money IMO.
Old 07-15-2009, 12:51 AM
Thanks man! Going to get this and there valve body with a larger trans pan in the next month or two.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
