F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-14-2009, 12:16 AM
I suppose there is a reason for no tranny drain plug
Why don't they put drain plugs in tranny pans? oh well. I drained the pan and the converter today on my '97 F150 4.6 , so i managed to get 12 qts of new fluid in. It has almost 180,000 mi on it and is starting to rust under the doors, so I was wondering if it is worth the effort, but hey the thing runs good, it's paid for, and I average about 16 to 16.5 mpg driving to work every day, so might as well treat it nice. Guess I should post pics, still looks good from a ways off, but get up close you can see the cancer lurking around the edges.
Old 06-14-2009, 12:30 AM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
production cost, ground clearance are two big points that come to mind. Atleast they put reuseable gaskets on them
plus you are lucky that you have a converter drain plug since they stopped doing that in mid 2000 i believe
Old 06-18-2009, 07:12 AM
Vehicle: 2002 Ford E350
Quote:
Actually it was shortly after the start of the 2002 model year.
Old 06-19-2009, 12:52 PM
Vehicle: 2001 ford f150
how do you get at the converter drain plug?
Old 06-19-2009, 12:56 PM
Vehicle: 2002 Ford F-150
I would figure that that reason there is not a drain plug becuase when you change the fluid, you should also be changing the filter, which you have to take the pan off to get to.
ΜΟΛΩΝ ΛΑΒΕ
"If we treated the 2nd Amendment like we treat the 1st, we would have the right to bear nuclear arms by now."
"When the people fear the government, that is tyranny, when the government fears the people, that is liberty!"
Pioneer AVIC F90BT in dash DVD/Nav
Trim Removed
PTM Bumper
5% Tint all around
Old 06-19-2009, 01:06 PM
glc glc is offline
Vehicle: 2003 Ford F150
Quote:
Open the inspection cover under the converter and turn the engine over till you see it.
Old 06-19-2009, 07:38 PM
Vehicle: 2002 Ford F150
I think the reason is that it is an infrequent operation and they didn't want the owners to do it. Maybe Ford was concerned with Joe Blow getting dirt in the tranny. Maybe it was to help the dealers make money.
I put drain plugs in mine. Buy them in the "Help" section at Advance or Autozone and I had to also buy an oil pan drain plug washer with a rubber inner ring to keep the plug from leaking. Those hard plastic washers the kit comes with do not seal that well.
I bought an Isuzu pickup years ago and the manual trans had a drain plug and the differential had a drain plug.
Roadie
2002F150LariatFX4Supercab5.4L
Old 06-20-2009, 04:25 PM
Vehicle: 2007 Ford F150
Thumbs up
Here are a couple of pics of a factory pan I bought and I TIG welded a 1/4" thread o let onto it for a drain.
http://i206.photobucket.com/albums/b...r/PICT0081.jpg
http://i206.photobucket.com/albums/b...r/PICT0080.jpg
2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
Injection is nice but ide rather be Blown!!!
Old 06-20-2009, 09:16 PM
Vehicle: 1999 Ford Expedition
My 99 Expy has a drain plug. I assummed it was factory but by what everyone is saying I guess it isn't?
Old 06-23-2009, 09:56 AM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
I would also say production costs. If you look at a 1994 owners manual, at least the Canadian version, there is no drain interval for the automatic transmission.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 06-24-2009, 12:21 AM
Yes, in the distant past, the manufacturers did not have a tranny fluid change in the maintenance schedule.
I remember my 82 TransAm had a 100k change recommendation. They expected that you would trade it before the trans needed a fluid change or maybe the rest of the car would fall apart before the trans needed a fluid change.
Roadie
Old 07-13-2009, 04:18 PM
Quote:
I have an 01 with 55,000 and the tranny has not been in for a service. I don't have the confidence to do a drain and fill on my own and from the research I've done, rather than having a flush done, I'd like to bring the truck in, have the pan dropped, TC drained, filter replaced, and tranny refilled. Did all 01's have a drain plug on the TC?
Old 07-17-2009, 01:02 PM
Vehicle: 2001 Ford F150
My 2001 has a drain plug in the TC - and I've used it. You can just spin the TC from the inspection hole with a big screwdriver or whatnot. Torque spec on the plug is 89 inch-pounds.
Do it yourself - get one of those black plastic trays for mixing mortar at Home Despot. They make a great catch pan for auto tranny service since they easily hold the dozen-odd quarts of ATF.
FORD OEM service manual says use a new TC drain plug each time. Does anyone really do this?
Feline truck mechanics Susie and Dukie
Old 07-17-2009, 03:08 PM
Vehicle: 2000 Ford F150
Quote:
Probably a combination of cheaper to produce and encourages owners to bring it to Ford for service (make more money). They are a business, after all.
Quote:
Yes, but make sure your truck is in neutral first.
I don't remember whether the original got cross-threaded or what, but I had to get a new one last time I did mine. Had to use a roommate's car to drive to the dealership. Probably good to have one handy, then you can return it if you don't use it. BTW, any standard $0.50 1/4" drain plug will "work," but the center of gravity may be a little different for plugs with a hex head. Not sure if that tiny bit will make a difference for TC longevity, but with how infrequently this needs to be done a new factory plug is affordable.
Jeff
2000 F150 XLT 5.4L 2WD
Black Sport with Flareside
Yokohama Geolander H/T-S G051 (265/70R17)
Ford 17"x7.5" FX4 (Type 15) Aluminum Wheels
PowerSlot Rotors on 4-Wheel Disc ABS
Rancho 5000 Shocks
Factory Tech Valve Body
SuperChips MAX Micro Tuner on "Performance"
Magnaflow Side-Exit Exhaust
Troyer Performance Dual 16" Electric Fans
Troyer Performance Underdrive Pulleys
AirForce One Stainless Steel Intake Kit
Old 07-17-2009, 04:20 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
The dealer doesn't want you servicing your transmissions. In the later years they even took the filler pipe away. Around 01 the TC drain plug vanished too. Some vehicles did have a drain plug in the pan, it could be stock.
Having the transmission in neutral makes no difference in turning the converter over.
Alan
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
