F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 07-17-2009, 07:35 PM
Vehicle: 2001 Ford F150
There's no filler pipe on newer trucks?
How the heck do you tell whether you are low on ATF or not?
Feline truck mechanics Susie and Dukie
Old 07-17-2009, 10:00 PM
Vehicle: 1995 ford tbird
Send a message via Yahoo to dirtyd0g
If it leaks you're low
Alan
Old 07-17-2009, 11:02 PM
Vehicle: 2002 Ford F150
Sounds strange not to have a dipstick or dipstick tube.
My 2005 Dodge Magnum Hemi does not have a dipstick, but it does have the dipstick tube. I'm supposed to take it to the dealer to get it checked. They have a computerized dipstick that measures the fluid temp and comes up with the measurement. German engineering I think since the trans is a Mercedes transmission. It's all BS as far as I'm concerned. All the other cars I've ever had has a high and low mark and you are supposed to check it hot. My wife's Mitsubishi 2.4L has a high or low for hot and cold. Why the hexx make something difficult when it is so simple?!
Roadie
2002F150LariatFX4Supercab5.4L
Old 07-18-2009, 01:07 AM
Vehicle: 1999 Ford Expy/SCREW
My 2001 has a drain plug in the TC - and I've used it. You can just spin the TC from the inspection hole with a big screwdriver or whatnot. Torque spec on the plug is 89 inch-pounds.
Do it yourself - get one of those black plastic trays for mixing mortar at Home Despot. They make a great catch pan for auto tranny service since they easily hold the dozen-odd quarts of ATF.
FORD OEM service manual says use a new TC drain plug each time. Does anyone really do this?
I just did a complete drain, filter and TC drain on my 01 SCREW and tried to reuse the TC drain plug. Next day I had a leak. Ran to Home Despot and got a brass plumbing one and that leaked too! Did the right thing next day and went to NAPA and got a steel one and no leaks. Moral of the story ---- REPLACE the TC plug.
Old 07-18-2009, 04:39 PM
I use good pipe sealer (not tape) on them and don't have problems with them. The Loc-tite teflon stuff works great.
Alan
Old 07-18-2009, 06:08 PM
glc glc is offline
Vehicle: 2003 Ford F150
Alan, why not Teflon tape?
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 07-19-2009, 01:06 AM
Teflon tape likes to tear off and go into the converter which makes it's way to the transmission. It could block a valvebody passage. I used to use tape when I had the converters apart and it really doesn't work that great either. The pink loc-tite stuff (510 I want to say) is the best ever but really hard to find and expensive. The teflon stuff works well. Right now I am using some stuff from homedepot. Not the chunky stuff it has to be the smooth teflon.
Alan
Old 07-19-2009, 02:16 PM
Vehicle: 2007 Ford F150
Exclamation
I've been a pipefitter/welder for 27 years now and have been using Teflon tape the whole time.There are some applications where I can't use it but most of the time can.If you start the tape a couple of threads up from the end you will never have a problem with it.The same goes with any thread type sealant/lubricant.
2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
Injection is nice but ide rather be Blown!!!
Old 07-19-2009, 06:20 PM
The smallest tape I find is 1/2 wide and there is only about 3/8 of threads. I use it on a bunch of stuff just not these little plugs.
Alan
Old 07-20-2009, 01:17 PM
Vehicle: 2000 Ford F150
Quote:
Originally Posted by dirtyd0g View Post
Having the transmission in neutral makes no difference in turning the converter over.
Alan
If I remember correctly (it has been a couple years) I had trouble turning my TC until I put the auto (4R70W) transmission into neutral. Any idea why, if not necessary?
I used Teflon tape in mine, just folded it in half and kept it a couple threads back from the inserted end of the plug, like BlueOvalFitter. Worked fine for me.
Old 07-20-2009, 02:09 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
Quote:
When your engine is running and the transmission is in Park does the car move? Just like in neutral it will not move even if the engine is turning. The only difference between is the parking pall that stops the rear wheels from turning while in park.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 07-27-2009, 10:26 PM
Vehicle: 2002 Ford E350
Yes, but make sure your truck is in neutral first.
There's some really bad advice for you. That just makes it more likely for the truck to roll and injure someone. The torque converter spins exactly the same in park as in neutral. And if the engine is off it also spins just as easily with the shifter in ANY position. Leave it in park for safety.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
