F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-14-2009, 02:08 PM
Vehicle: 1999 Ford F150
Quote:
Originally Posted by glc View Post
I'm afraid I don't, but I do recall seeing threads on this issue here. Something ain't right either in the column or down at the tranny. It's not an internal tranny issue.
On another topic, if you are planning on putting a 4BT in there, you need to research the engine redline carefully before you put 5.38's in there. Diesels generally can only be run to about 1/2 the RPM's of a gas motor, I think even with huge tires, 5.38's may be too low for highway operation. Just a suggestion.
Ok ill search some more for threads pertaining to the problem thanks.
the axles are already under the truck, i was told that they had 5.13's in them when i bought them. But for some reason it just seems way to low for 5.13's you seriously can drive in grass, dirt or gravel without spinnin. So im gonna have to check into the gearing more.
Ive seen some swaps running 2.5 Rockwells on the 4bt and thats crazy gearing. So im gonna have to run trial and error on that. If i have to ill change the gears to something else.
My truck RARELY sees 60+ MPH so im gonna run with it now. Ill have to get it on the road to see what RPM's im cruisin at.
thanks again
Old 06-14-2009, 03:22 PM
glc glc is offline
Vehicle: 2003 Ford F150
I'm gonna make an educated guess here - based on a vague recollection. I *think* there's a cable going to the transmission that moves the gear selector - and an extreme lift kit may be stretching that cable too tight and it's binding.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-14-2009, 03:27 PM
10-4. not really sure how the suspension lift would stretch it. But im sure my body lift stretched it. Maybe its just going out.
Im gonna find said cable and follow it all the way back and see if its getting bound up. if its not that then ill check the column area.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
