F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-10-2009, 09:58 PM
Vehicle: 1997 Ford F150
Adding B&M supercooler
Just wanted to get some input here...
Truck has the factory installed cooler. I'm towing a 5000 lb travel trailer and the truck does ok, but the transmission temp is getting near 205 F (added mechanical gauge located in pan). I have a B&M supercooler and the instructions say to mount it in series with the oem cooler. At the risk of being laughed at for using paintbrush ... is this how I should do it?
Stock
Modified
Old 06-10-2009, 10:01 PM
Stock
Modified
Uhhh... where are the pictures? I put them in my photo album and linked to them...
How about this?
http://www.f150online.com/forums/mem...33432-oem.html
http://www.f150online.com/forums/mem...3433-oem2.html
Old 06-11-2009, 05:33 PM
Vehicle: 2003 Ford F150 FX4
I prefer to take the factory ones right out and replace with something bigger in hopes of keeping the line pressure close to stock. To me the stock cooler won't be doing jack with the B&M in there and then there is all the extra line and connections to leak.
If you wanted both I would have it go to the OEM cooler first then to the B&M and back to the trans. The B&M is where it will get all the cooling so I would want that to get back to the trans as fast as possible. Just my two cents.
2003 F150 4x4 FX4 (White): 5.4L, Custom Tuned Gryphon Programmer, DIY Air Intake Mod, True Duel Straight Pipes With X-Pipe, Factory Tech Separator Plate, F250 SD Trans Cooler, Digital Trans Temp Gauge, Timbren Rear Suspension Enhancement System, Mag-Hytech Rear Diff Cover.
Old 06-11-2009, 08:58 PM
Vehicle: 2002 Ford F150
If you live in the frozen north, it may be best to mount it before the radiator so the fluid will be warmed in the winter.
Roadie
2002F150LariatFX4Supercab5.4L
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
