F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-09-2009, 01:40 PM
Vehicle: 2004 Ford F150
tranny service
I have an 04 F150, 4.6l. Just turned 60k mi. 30k mi w/ a 6in lift, 35's and 4.56's. Wanna get the tranny serviced. For a full fluid exchange I've gotten quotes from $140-200. Not including filter change. Are these estimates accurate? Tranny temp running in the high 160's to low 170's on avg. Usually only got as high as mid 150's.
Old 06-09-2009, 11:20 PM
Vehicle: 2000 Ford f150
Send a message via AIM to kirkmears Send a message via Yahoo to kirkmears
i would never take mine anywhere for service again. my last transmission went out 2 months after taking it to get flushed (4R100 w/ 60k).
if you do get a flush, do yourself a favor and go to the dealer. hopefully someone there will know what they're doing...maybe.
i would suggest dropping the pan yourself and just replacing the filter & fluid. when you replace the pan, get an upgraded B&M pan if you got the money with a drain plug. just my 2 cents
edit: oh...and those prices sound roughly bout right. dealer's probably closer to 200...
Last edited by kirkmears; 06-09-2009 at 11:22 PM. Reason: addin info about prices...
Old 06-10-2009, 12:14 AM
Vehicle: 2007 Ford F150
I am also curious about this.
2007 Ford F-150 King Ranch 4x4, 2" A/S, JL Audio TR570-CXi, Weathertechs, Passport 9500i, NFab LB 4x PIAA 520s, Bilstein 5100s in rear
2009 Lincoln MKX
2006 GMC Sierra 2500HD 2WD LBZ, Banks Six-Gun, Magnaflow 4", Banks RAM-AIR, T-Bars cranked, Weathertechs
2007 Honda CR-V EL-X 4WD
2004 Chevy 3500 Duramax Dually 4x4
1997 Chevy 1500 Suburban 2WD
Old 06-10-2009, 06:11 AM
I have a Mag Hytec pan with cooling fins and a drain plug. I works like a charm. Very simple to drain the pan and then top it off at the dipstick.
Old 06-10-2009, 12:06 PM
glc glc is offline
Vehicle: 2003 Ford F150
Dropping the pan only drains about 1/3 of the fluid. You need to use an exchange machine to get the fluid out of the torque converter.
2003 F150XL 4.2 short cab/bed 4x2 5 speed manual 3.55 LS
Old 06-10-2009, 08:17 PM
Vehicle: 2002 Ford F150
Quote:
I know that the 4R70W transmission also has a drain plug in the torque converter so you can drain all of it. My 2000 F150 5.4 had one. My 2002 has one. My 95 Mark VIII 4R70W had one. My son's 2000 V6 Mustang has a 4R70W and its torque converter has a drain plug.
You can also go to your local parts store and buy a drain plug kit for the transmission pan. Just drill a hole in your pan where the plug doesn't interfere with any internal stuff and install it. I use an oil pan drain plug washer to keep it from leaking. It's a steel washer with a rubber ring inside the circle. I had one leak with the nylon washers that came with the kit. Also, our transmissions come with a very good reusable gasket.
Old 06-10-2009, 11:44 PM
What does Ford recommend? Flush or pan drop?
2009 Lincoln MKX
Old 06-10-2009, 11:58 PM
All the dealers use the machines now I believe. Saves time for them and they make more money.
Roadie
2002F150LariatFX4Supercab5.4L
Old 06-11-2009, 12:49 AM
It is obvious that since a pan drop only replaces 5 quarts, and a flush replaces all 14 quarts, that a flush is better. However, don't forget the filter. Depending on mileage, it would be a good idea to drop the pan, change the filter, then hook up the flush machine.
Old 06-11-2009, 05:15 AM
glc glc is offline
They discontinued the torque converter drain plugs in 2001 or 2002 sometime. An 04 won't have one.
Old 06-11-2009, 09:00 PM
Like I said, my 2002 torque converter has a drain plug. Don't know about an 04.
Roadie
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
