F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-08-2009, 12:22 AM
stuck in 2nd
2000 F150 2wd with 89,000 miles. Gets stuck in 2nd gear. When I hit about 45 mph it stops accelerating and the motor just revs up. When I turn the OD off it still won't shift out of 2nd but I can accelerate. I just changed the transmission filter and still have the same issue. Any ideas
Old 06-09-2009, 09:17 AM
Vehicle: 2001 Ford F150
Is the OD light flashing at you?
2nd gear is the default gear. Its what you get when no electrical input is applied to the shift solenoids and therefore what is used for 'limp home' mode for the transmission.
Usually this menas the computer saw a serious electrical issue or that something has come unplugged. If the OD light is flashing then there is a stored code that can be read out by a sho with a GOOD scanner. That means you can't go to autozone or the like. You need to find a shop with a quality scanner that can read Ford transmission codes. If someone tried to read the code with an inferior scanner they won't get the code, but they will erase it.
Darrin
Old 06-09-2009, 11:14 PM
thanks Darrin.
the od light doesn't flash and I am getting no check engine lights or anything. Do the lights need to come on before a scanner can be hooked to it?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
