03-21-2009, 09:16 PM
Vehicle: 2000 Ford F150
HELP - Found in Tranny Pan - 2000 F150
14bolt tranny pan - 4.6 engine
I'm in the process of changing the tranny fluid. When I dropped the pan there was a yellow plastic plug with an oring on the end in the bottom.
The piece looks like one of those "tops" you would spin when I was a kid.
Does this piece go in the bottom of tranny somewhere or do I have a bigger problem?
Any help is appreciated
03-21-2009, 09:35 PM
Global Moderator & Senior Member
Vehicle: 2005 Ford F150
Quote:
Originally Posted by
hoseguy
it's the plug they have in the tube to keep the foreign matter out until the stick is put in at the factory. It gets shoved through, no problem. Throw it away. It means the pan has never been dropped.
Flowmaster 40, K&N dropin, Tint, Roush wheels, 305/50/20s
Edge Evo with PHP custom tunes, GF 2" shackles
03-21-2009, 09:41 PM
pheww...thanks
i was sweating the load..
any tricks or tips while i got the pan off?
03-21-2009, 09:51 PM
hoseguy
pheww...thanks
None I know of.
03-22-2009, 09:26 AM
Vehicle: 1997 Ford F150 5.4
hoseguy
pheww...thanks
Remember to fill it back up after you reinstall it...
03-25-2009, 11:26 AM
Vehicle: 1999 Ford F150 4x4
projectSHO89
Funny guy.
Install a drain plug. I think mine went in the front left corner, IIRC. And seal it up
real good. Blue RTV, JB Weld, etc.
BTW, that little yellow plug has been the source of many a raised eyebrow, mine included.
Andy
03-25-2009, 11:35 AM
Vehicle: two 2003 F-150s
you could do the Jmod while youve got the pan down, you're halfway there
03-26-2009, 06:33 PM
Vehicle: 2007 Ford F150
hoseguy
You need to head to your nearest Ford dealer to have the o-ring decoded to see if you have won a 74 Pinto or a 76 Gremlin!
2007 F150XL,4.2V6,3:55 non L/S,auto
Dark Blue Pearl Metallic
Injection is nice but ide rather be Blown!!!
04-01-2009, 02:43 AM
I cleaned mine off real well. Now I use it to bite on when I get tattoos.
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
