F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-21-2009, 09:31 AM
Vehicle: 2001 Ford F-150
Trans temp sender location (4R70W)
I have read over several threads on where to put the sender for the trans temp. It seems the overall location has been in the trans cooler line going into the radiator. I have also read to put it in the port on the side of the trans. Just wondering what would give the best readings so that I'm getting good temp numbers. Just curious as I recently bought a newer and bigger boat and tow it with overdrive off. I also just had 4.10 gears installed to help with the pull. It currently turns about 2600 rpm at 60 mph. Just want to make sure I'm not tearing anything up. Thanks for the response.
Old 03-21-2009, 04:31 PM
Vehicle: 2001 Ford F150
What size tires and year truck? Also Just try to stay around 180 degrees and I installed mine in the pan with a bung. It has to be welded to the pan but not a bad project.
2001 5.4 Screw 4x4,6 inch trailmaster lift,Chickenears intake,Lightning grill and headlights,Autometer Tranny temp gauge,boost gauge Wideband A/F,Kanamari ram air hood,lightning motor swap,xcal3 tuned by Justin @VMP.
Old 03-22-2009, 09:20 AM
Sorry, it's an 01' Screw with the 5.4L. The tire size is 275/55/20. Thanks for the info.
Old 03-22-2009, 10:05 AM
Vehicle: 2002 Ford E350
I like the sender in the test port. It gives temp readings within a few degrees of the pan, sometimes higher, sometimes lower, but always close.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Old 03-22-2009, 11:54 AM
Ideally you would be able to monitor it from a couple locations. Since I deal a lot with performance stuff, I like to see the temp of the fluid coming out of the transmission.
Darrin
Old 03-25-2009, 09:10 PM
Vehicle: 2001 ford F150
i put mine in the test port. works great!
2001 F150 5.4 ext. cab 4X4, 6" RCD susp. lift, PA body lift, 35" Nitto Mudgrapplers, Superchips Tuner, 3.55 gears
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
