F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-19-2009, 05:01 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
T-case interchangeability F-150 & F-250
I know for a fact that output shaft on the 4x4 M5OD-R2 on the 97+ F-150 has the same spline count and diameter as the output shaft on the BW-4406 manual shift transfer case. I verified this by sliding the slip yoke from my driveshaft over the out put shaft of the transmission.
I also know that the input shaft of the SuperDuty Manual shift transfer case is of the same spline count and diameter as the BW-4406. I did this by removing the output shaft of a BW 4406 and sliding it into the input shaft of the SuperDuty Transfer case. I know that the mounting bolt pattern of both transfer cases are the same. The both use the same gasket. So by logicvl reasoning the SuperDuty transfer case will bolt onto the M5OD-R2. It also means that the BW-4406 will bolt onto the ZF manual transmissions found in the SuperDuty. I can only assume that the Automatic transmissions and Electric transfer cases would follow suit as there is no distinction between the BW-4406 behind the 4R100 and the 4R70W.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 03-19-2009, 05:22 PM
Vehicle: 1997 Ford F150
So your saying that I do not need to get the transfer case for the zf6 transmission when I do the swap also have you happened to find out where the shifter is located, I have been waiting for a f250 with the zf6 transmission to roll on into my friends transmission shop so I can check but either they are not that common or they just dont break that often
1997 Ford F-150 XL | V8 4.6L | 4X4 | Manual Transmission | True Dual Exhaust(Magnaflow Cats, Flowmaster Mufflers) | Hedmen Headers | K&N Cold Air Intake | Flareside Body
Old 03-19-2009, 05:40 PM
JMC JMC is offline
You may have to fab up a linkage adapter for the t-case but I am not sure. I will measure the distance of the t-case shift lever from the mounting surface on both and let you know. Both shift levers move in the same direction to engage but the throws may be different lengths.
Regards
Jean Marc Chartier
Old 03-20-2009, 05:28 PM
hmm sounds like a plan, I also wanted to ask you if how your truck runs while off roading and towing with the short throw shifter and how much shorter is it than the stock shifting
Old 03-20-2009, 07:05 PM
JMC JMC is offline
The throw is reduced about 30%. There is no difference in how the truck performs other than reducing the time required to shift gears. That makes the truck run the 1/4 mile faster.....
Regards
Jean Marc Chartier
Old 03-20-2009, 08:07 PM
nice I may have to look into that kit
Edit: where did you get that kit I cant find it at any of my usual shopping places(ie summitracing.com and jegs.com)
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
