F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-16-2009, 12:43 AM
Vehicle: 2008 ford f150
5 or 6 speed manual swap on 97
has anyone swapped a manual trans. from a 3/4 ton to a automatic 97 half ton 4x4 with 5.4? is gearing any different between the two? will shifter location be an issue? is it possible to swap in an older trans like a 4 speed?
my automatic is gettin kinda tired.
Old 03-19-2009, 01:27 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
In order to use a manual transmission in an automatic vehicle you will need to purchase the pedals, reprogram the PCM to eliminate the transmission control functions, cut a hole in the floor of the truck, install a flywheel and clutch kit, including the pilot bearing, and install a clutch control system. The gearing is obviously different as you are going from a 4 speed to a 5 or 6 speed. If you mean differential gearing then there is no difference between the two transmission options. Why would you want a 4 speed manual transmission? I would recommend a ZF transmission from a SuperDuty.
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
