F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-12-2009, 02:57 PM
Vehicle: 1979 ford f150
Transmission question
Hi, I'm a newbie to the site and I have to say, thank the good Lord,that I found it. I have 79 F150 with a 302 in it. I believe that I have a C6 Transmission in there right now, but, could be a C4. I want to swap it out for an AOD trans, but I need to get some details as to what I'm looking for and things that I need to be mindful of when I do decide to do it. Has anyone done this swap to a 79 or earlier model or does anyone know of some good resource sites that they could to direct me to.
thanks.
Old 03-14-2009, 02:49 PM
Vehicle: 2008 Ford F150
i caint give you a 100% answer. but i know there is a year split when they went to electronic. you dont want that you want an old fashion stupid AOD. another thing to consiter is getting the AODE they are more heavy duty and came out of econolines and newer f150s and such. but besides that it should be simple, bolt up to the engine only things would either be modifying the cross member or making one and a new driveshaft to match the length and output shaft of the trans
•2008 F150 FX4• 6" Fabtech Dirtlogic Lift, 35x12.5/18 pro comp xtreme at, 3inch exhaust with straight through muff..
Old 03-14-2009, 07:00 PM
Vehicle: 2002 Ford E350
Quote:
They started changing from AOD to AODE (the "E" means electronic) in 1992.
So which is it, does he want the AOD or the AODE? You said don't get an AODE, then said that's what he wants.
An AODE is MUCH more complicated to install. You need the computer and wiring to make it run, the AOD just needs the TV cable adjusted correctly.
The AODE was also available in the cars. My son has a '92 Grand Marquis with an AODE.
Old 03-16-2009, 10:44 AM
found the answer
After I posted this question, I scoured the internet and then talked to a couple of folks. their suggestion was the AOD because of the straight bolt on, with a few modifications. one being the cross member, it will have to be moved back 2 to 3 inches to accomodate the AOD. also the linkage, if remember correctly, is different. I suppose that it is when you guys talk about the tv linkage. What's that all about anyways. Please excuse the ignorance on this stuff, like I said Newbie....
Old 03-16-2009, 12:48 PM
TV is throttle valve. The AOD needs this linkage (sometimes a cable) to be controlled by the throttle opening. It sets the pressure inside the trans. It is critical to get this exactly right or the trans will have a very short life.
Mark
Former Ford Automatic Transmission Engineer, 1988-2007
Old 03-16-2009, 12:58 PM
Thanks Mark, now I have a better understanding. I can buy a rebuilt AOD trans that came off of a 85 Econoline Van for 375. gentleman told me that he had it rebuilt for hooking up trailers and what not. I guess that it is pretty stout.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
