Truck runs in overdrive. If You push the button to lockout OD, fuse blows. Other times, normal driving, OD off light flashes.
Checked column wires for frayed wire, all ok there. Friend tells me either the OD switch, sensor in differential or sensor on tranny. I was also told to watch for fluxuation on speedo when light flashing. Needle stays where it should be, no variation.
There is no sensor that can blow a fuse when the OD button is pushed. The only way that can happen is if there is a short to ground in the wire between the button and the PCM. You'll need to find where the short is and fix it.
You might also want to read the codes. When the OD light flashed a code was stored. I think that might be more than the OD button.
__________________ Mark
Former Ford Automatic Transmission Engineer, 1988-2007
I pulled the cap and switch. All looks ok there. As I stated in my original post, wires down the column look ok too. I guess I'll trace them to the end this weekend.
